ARMD
Mar 28, 2022Aspirant
Nighthawk app not logging in to r7000 router
running iphone ios 15.4 unable to log into my router with the nighthawk app. i have changed the router password and deleted the special characters without success. i have deleted the nighthawk app s...
ARMD
Mar 29, 2022Aspirant
any other insights into the app issue?
Mar 30, 2022Guru - Experienced User
we're waiting on netgear to have a response/app update as well.
I've seen some try a factory reset but it doesn't help many
- ARMDMar 30, 2022Aspirant
there was a recent app update but it did not help. i do not want to reset the router and will wait and see.
- calliApr 03, 2022Guide
Had the same problem with the Nighthawk App - timed out.
Solved the problem after reset - it had 2 active logins.
Told it to close them and then opened setting on PC.
Nighthawk then miraculously worked and is still working.
- ARMDApr 03, 2022Aspirant
what did you reset. did you reset the router back to factory settings?? If so i have trusted devices on my network by using access control. will i have to readd all these devices again if i reset the router?
