ARMD
Mar 28, 2022Aspirant
Nighthawk app not logging in to r7000 router
running iphone ios 15.4 unable to log into my router with the nighthawk app. i have changed the router password and deleted the special characters without success. i have deleted the nighthawk app s...
jbraun
Apr 18, 2022Tutor
As others have mentioned, I used to be able to login into my R7000 router with fw V1.0.11.134_10.2.119 using the Nighthawk Android app. I can easily login via regular browser (on same phone as app even), I've uninstalled the NH app but no difference. Not sure if this happened after last fw upgrade.
- ARMDApr 18, 2022Aspirant
I had to factory reset router and reinstall my settings. relogging in to netgear app now works. i just updated the netgear app and same issue happened and again had to reset router and reimport my settings. now the app once again works on my iphone. it is a pain in the neck to have to keep doing this and not sure why it is happening.
- ARMDApr 22, 2022Aspirant
my nighthawk app keeps kicking me out of my router and i have to keep factory resetting it. this is annoying and not sure why this keeps happening.
