Shane-Woodend
Oct 04, 2020Aspirant
Nighthawk App not retaining Saved device names
I have an R6020 AC750 WiFi Router and I run the Nighthawk App on my Nokia phone (Android 10). There are 2-3 devices that always show up in the Device Manager as "Unknown". I have identified what thes...
Christian_R
Oct 09, 2020NETGEAR Employee Retired
Hi Shane-Woodend,
May you reinstall the Nighthawk app and power cycle your router.
Christian
Shane-Woodend
Oct 09, 2020Aspirant
Thanks for your suggestion, just finished going through that process, unfortunately it did not make any difference at all.
- Christian_ROct 12, 2020NETGEAR Employee Retired
Hi Shane-Woodend,
Thanks for confirming. May you access the router's admin page by visiting http://www.routerlogin.net/ using a web browser. Please let me know if you're able to edit the attached devices list using the admin page.
Christian
