Magman's avatar
Magman
Nighthawk app not showing on/off toggle for iPhone
All my connected devices on the 2.4 GHz band display an on/off toggle switch but the only device on the 5 GHz band (an iPhone) doesn't have an on/off switch. Is this normal, or is there something wro...
  • schumaku's avatar
    Sep 29, 2019
    That's the device you run the Nighthawk App on - you don't want to cut the branch you sit on, don't you?
