shujaat118
Sep 19, 2020Aspirant
Nighthawk App not supporting D7800
Hi I tried nighthawk app today but got a message D7800 is not supported. See attached screenshot. Am i missing something? D7800 works fine with genie. I just wanted to switch to nighthawk app. ...
michaelkenward
Sep 20, 2020Guru - Experienced User
That's why the Nighthawk app does not work. You need new firmware on the D7800 to that to work. Get that and it kills the Genie.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Notice the lack of any DSL modem/routers in there.
If you are lucky, Netgear will not update your firmware. The Genie app is generally reckoned to be a lot better than the Nighthawk app, which kills some useful features.
Why do you want to make the switch?
- shujaat118Sep 21, 2020AspirantI thought to switch because Netgear no longet updates genie. I received an email from Netgear to switch to Nighthawk app.
- michaelkenwardSep 21, 2020Guru - Experienced User
shujaat118 wrote:
I thought to switch because Netgear no longet updates genie. I received an email from Netgear to switch to Nighthawk app.I don't know what that email said. It may have been one of those generic messages sent to everyone who has signed up for emails.
There is no point in trying to use an app if it does not support your hardware.
Netgear may not update the genie, but it works now.
Apps are tied to firmware. If Netgear updates your firmware, you may be able to switch to the Nighthawk app.
But we still do not know what you actually want to use an app to do.
