Retired_Member
Jul 28, 2021Nighthawk App Not Working after Firmware Upgrade (Nighthawk MK-83)
I did a manual update of my Router and Satellites with Tech Support. The iPhone app is now useless. The Network Map shows only my Router and two of my three Satellites. When I go to the Device Manage...
Retired_Member
Jul 28, 2021I did uninstall the app, restart my iPhone and then reinstalled the app. Both my iPhone and iPad are still having the same problem.
I just did a factory reset with Tech Support - after we did that, this problem started. They had no solution. Why would the web app make a difference?
Jul 28, 2021Guru - Experienced User
Wouls help to get the system setup first using the routers web page, then after its setup, the NH may work after that. If not, NG support will need to pass this to the app team for review.
- Retired_MemberJul 28, 2021
I have the system up and running. Tech Support had me factory reset and start over using the app. It is operating fine except for the app - the network map is incorrect (missing a satellite) and the device manager returns an error.
- FURRYe38Jul 29, 2021Guru - Experienced User
Keep in contact with NG support then.
- Retired_MemberJul 29, 2021
I have tried that - absolutely no response - very frustrated.
