Retired_Member
Jul 28, 2021Nighthawk App Not Working after Firmware Upgrade (Nighthawk MK-83)
I did a manual update of my Router and Satellites with Tech Support. The iPhone app is now useless. The Network Map shows only my Router and two of my three Satellites. When I go to the Device Manage...
Bjbrads
Dec 20, 2021Aspirant
I am having the same issue as others where after the router update, now the nighthawk app does not work. Netgear support and products are useless pieces of ----. You cannot get any help to resolve the issue. Also netgear routers are widely known for their back door access. Really no privacy or security.
michaelkenward
Dec 21, 2021Guru - Experienced User
What about this place?
I see no sign that you have tried to get help anywhere else in this community.
You have joined in on an old discussion about different hardware. (Apps and firmware are linked together.) So it might be worth beginning afresh.
We'll need a detailed description of your problems and your network before anyone can begin to guess as to what might be going wrong at your end.
The R6400 in your footer isn't one of the usual suspects on the troublemaker front. It has been around since 2015 and has had time to bed down.
