improvizr's avatar
improvizr
Follower
May 07, 2023
NIGHTHAWK App not working on Android
Just installed Nighthawk app on my Revl + 5G phone. It starts, then freezes and quits. Can't configure my router without it apparently, since trying to set up from a laptop doesn't work with an internet connection. Just trying to configure as an access point to plug into existing router and extend service. WHY IS THIS SO HARD???
1 Reply
  • michaelkenward's avatar
    michaelkenward
    It is usually a lot easier to set up and configure a device with a wired connection to the router and the browser graphical user interface (GUI)
    It is actually pretty simple and is not something that you should even try with the app.
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    You don't say which Netgear router you are using. Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    Check the manual for something like Use the Router as a Wireless Access Point. The wording may differ depending on the model number.
    Does your anonymous router support the Nighthawk app?
    Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
