titanicnut
Feb 06, 2023Star
Nighthawk App not working properly
I have a Nighthawk CAX80 and am using the Nighthawk app on an iPhone XR, Samsung phone and 2 window laptops. #1: The app only connects with anywhere access. If I try to connect locally it shows me ...
- Feb 06, 2023I went and bought another CAX80 and the issues with the nighthawk app have been fixed
marialopez1
Feb 06, 2023Aspirant
It sounds like you're having some issues with the Nighthawk app and your Nighthawk CAX80 router. It seems that the app is only connecting with "anywhere access" and is not able to connect locally, causing issues with the traffic meter and the protection status of your devices. I would suggest reaching out to Nighthawk APK technical support again, as they have indicated that a recent update may help resolve these issues. Additionally, you may also want to try resetting your router and ensuring that your phones and laptops are running the latest software updates.
