titanicnut
Feb 06, 2023Star
Nighthawk App not working properly
I have a Nighthawk CAX80 and am using the Nighthawk app on an iPhone XR, Samsung phone and 2 window laptops. #1: The app only connects with anywhere access. If I try to connect locally it shows me ...
- Feb 06, 2023I went and bought another CAX80 and the issues with the nighthawk app have been fixed
titanicnut
Feb 06, 2023Star
Thanks for the reply!
I already have local access enabled for the nighthawk. I disabled the wifi IP in my phone.
** no change **
I turned on the traffic meter in the UI. It’s works now!!
From the nighthawk app it gives a link to install bitdefender. We installed the app it told us to download. The one laptop that shows up downloaded bitdefender same as the other laptop and the phones.
** no change **
Feb 06, 2023Guru - Experienced User
I guess wait for the next NH app update and go from there...
