jawadnawaz
Feb 07, 2025Tutor
Nighthawk app on Android is crashing
I have RAX70 router and Nighthawk app version 2.43.0.5521 on my mobile setup. On the app, I have setup profile for my kids in Device Manager. On the profile I set policy like bedtime, usage time et...
Feb 08, 2025Guru - Experienced User
Does it happen on any other devices?
Or just the one?
What device is it? What version of android is it?
jawadnawaz
Feb 09, 2025Tutor
Yes I have tested on multiple devices, Samsung galaxy 24, google pixel 7pro, xiaomi ipad. All latest upgraded version of OS and pathing.
- plemansFeb 10, 2025Guru - Experienced User
You have a newer version it looks like?
I'm on 2.43.0.4421what version of android are you on? I'm on 14?
- jawadnawazFeb 11, 2025Tutor
As I mentioned in the org thread that all devices are updated to the latest of OS and patches, router, android devices, app.
There has been some latest firmware updates or support disconnection of the app, that's why many people are facing this issue. Unfortunately I don't have the Netgrear support, otherwise, I would ask them. Anyone who has bought the device lately and has support, pls populate the thread with the Netgrear support response. Thanks
- plemansFeb 12, 2025Guru - Experienced User
T
Your "latest" isn't always what everyone else's is. If the mods are looking at it, the more info you put like your actual OS version helps them help you faster. LIke how my "latest" app was a lower version than yours. Its not just helping you out, but others that might have this issue. Thats why we ask for actual numbers in the forums and not for people to just put "the latest"
