lionheart_2281
Jun 20, 2019Tutor
Nighthawk App on iOS can't find Nighthawk X4S AC2600 D7800 in Australia
As per the subject, is this normal? I just updated to the latest firmware and it still doesn't find it. Kinda ironic that Netgears App that's literally called Nighthawk can't find a Nighthawk mo...
- Jun 22, 2019
*GROAN*
Thanks for your help, I really appreciate it, kudo's to you
schumaku
Jun 21, 2019Guru - Experienced User
lionheart_2281 wrote:As per the subject, is this normal?
Yes, and nowhere in the world - not only in Australia.
lionheart_2281 wrote:Kinda ironic that Netgears App that's literally called Nighthawk can't find a Nighthawk modem/router
Indeed. However the Nighthawk App does currenlty only suppot selected [Ethernet] routers, no xDSL or Cable or Mobile or whatever other routers carrying the Nighthawk name. FMI: Which products support the NETGEAR Nighthawk app?
In my opinion, you might be lucky and your router continues to be supported by the Netgear Genie App and Genie deskop programs - not sure why you are so keen on the "new" one - as Genie is ways ahead: Which NETGEAR home router models can I manage using the NETGEAR genie app?
- lionheart_2281Jun 22, 2019TutorDelete
- lionheart_2281Jun 22, 2019Tutorhttps://kb.netgear.com/000055505/Which-products-support-the-NETGEAR-Nighthawk-app
Says it supports AC2600- schumakuJun 22, 2019Guru - Experienced User
Says it supports AC2600Blame Netgear for their awful mess of product designations please. Your product model is D7800, Nighthawk X4S is some marketing designation, and AC2600 is a summed-up total wireless capacity. Silly but true, Netgear does also have a product model AC2600 - and this is what is referred.
*GROAN*
