MBChappers
Jun 08, 2019Aspirant
Nighthawk app pause sliders grey eyed out
My nighthawk app is version 2.3.6.7 being run on an iOS device & my R8000 and my EX7300 are both running the latest firmware. I am having trouble with the app whereas the pause sliders in the devi...
michaelkenward
Jun 09, 2019Guru - Experienced User
Not sure that I understand the message, and the description of what is going on, but mobile apps do not support extenders.
MBChappers
Jun 09, 2019Aspirant
I’m not on about the extender. I just put this on just in case it had som bearing on the issue.
The issue is with the device manager in the nighthawk app. It is supposed to be able to pause any connection through the router but all tha sliders are greyed out in the app. If I access the router, I can use access control and it works ok.
