Paperboy61
Sep 11, 2020Tutor
Nighthawk app puzzle
Along with a number of other problems I am having with the A7000, is that the app is showing some odd things.
In the Device Manager section, it wasn't showing that my Tivo box, which is wired directly to the A7000, is not wired, but connected wirelessly. I moved the ethernet cable to a different input and now it shows it as being wired AND wireless. Also my iphone is showing as connected, but it is the only one that doesn't have the pause/resume toggle button. Should I be concerned?
Sort By
- sovepInitiate
Hi buddy, chill out, this is normal. Nothing to worry about!
Regards,Joshua Genin
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
The A7000 has nothing to do with the Nighthawk app.
