noraiko
Nov 22, 2019Tutor
Nighthawk App Router Setup Loop
Hello! I have my Nighthawk X4 AC2350 upstairs, which is connected to an ATT BGW210 router downstairs in attempts to boost the signal upstairs. The Nighthawk router wifi currently has the same name/pa...
- Nov 24, 2019
Thank you so much for your responses! I did a bit more research since I was still having issues turning on the AP mode on the router per your suggestions, and I stumbled upon this: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7500v2-firmware-1-0-3-40-not-functioning-as-AP/m-p/1697828/highlight/true It seemed to help with my issue, as I now have full wifi bars, and all of the illuminated lights are white.
TLDR Had to reset the router yet again, and revert the firmware version 1.0.3.38 before turning on the router's AP mode.
Nov 22, 2019Guru - Experienced User
The problem is that you're running both routers in router mode. Its causing a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
You either need to place the att device in modem only mode or you need to switch the netgear router to AP mode. this will fix a lot of your conflicts.
to access/managed the netgear router, unhook it from the att device. then try to go through the setup. This will let you manage and switch it to AP mode. Once switched, hook it backup to the Att device.
michaelkenward
Nov 24, 2019Guru - Experienced User
Spot on there, but here is the bad news:
Solved: How can I put BGW210 gateway on bridge mode? - AT&T Community
from
