noraiko
Nov 22, 2019Tutor
Nighthawk App Router Setup Loop
Hello! I have my Nighthawk X4 AC2350 upstairs, which is connected to an ATT BGW210 router downstairs in attempts to boost the signal upstairs. The Nighthawk router wifi currently has the same name/pa...
- Nov 24, 2019
Thank you so much for your responses! I did a bit more research since I was still having issues turning on the AP mode on the router per your suggestions, and I stumbled upon this: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7500v2-firmware-1-0-3-40-not-functioning-as-AP/m-p/1697828/highlight/true It seemed to help with my issue, as I now have full wifi bars, and all of the illuminated lights are white.
TLDR Had to reset the router yet again, and revert the firmware version 1.0.3.38 before turning on the router's AP mode.
noraiko
Nov 24, 2019Tutor
plemans thank you for your response!
I attempted to set the router into AP mode, but I'm not sure if I've successfully done so. I reset the Nighthawk router, and was able to access routerlogin.com. However, after setting the router to "AP mode" there was a failure message. I didn't clearly see what it was, and I haven't been able to get the router to let me back onto routerlogin.com to try again (even after trying to reset it again). When I tried setting it to AP mode, I had the router plugged into the wall plug that's been giving the ATT router a connection.
Now when I plug the Nighthawk to the ATT router, the internet light is orange. Is this normal for a router in AP mode? Attached is a picture of the router and its illuminated lights. I'm in the same room as the router, and I've only got 3/4 bars as opposed to all four of the bars being on while I had the double NAT going.
Thank you so much again for your response and time!
noraiko
Nov 24, 2019Tutor
