JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
Christian_R
Mar 05, 2021NETGEAR Employee Retired
Hello JoeM11,
Thanks for the feedback. Would you mind providing the model number of your router, the current firmware version it's on, and the Nighthawk app version you have installed for me to check on this further.
Thanks,
Christian
- JoeM11Mar 05, 2021StarModel C7800
Firmware: v3.01.43
App: 2.8.5.16- Christian_RMar 05, 2021NETGEAR Employee Retired
Hi JoeM11,
Christian
- michaelkenwardMar 06, 2021Guru - Experienced User
JoeM11 wrote:
Model C7800
Firmware: v3.01.43
App: 2.8.5.16Cable devices, modems and modem/routers, are mostly beyond your control. Or Netgear's come to that. Only your ISP can update your firmware:
So it is a real puzzle if an app throws up a message like that.
- JoeM11Mar 10, 2021Star
This is still not working....please update your App and fix the issue
