JoeM11's avatar
JoeM11
Star
Mar 03, 2021
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version.  Probably an App issue but they need to get this fixed.
  • Christian_R's avatar
    Christian_R
    Mar 05, 2021
    Hi JoeM11,
    Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
    Christian
