JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
Óscar
Jul 28, 2021Tutor
I also get the firmware out of date on the nighthawk application. I am on spectrum and they told me the firmware is up to date. I contacted Netgear and they couldn't help me because my warranty expired and I needed to pay. They can't fix this small problem. Please fix this problem.
- FURRYe38Jul 28, 2021Guru - Experienced User
You'll need to disregard the FW update message in the app.
- ÓscarJul 28, 2021TutorHow would I discard that massage? I don't see any way to discard
- michaelkenwardJul 29, 2021Guru - Experienced User
Óscar wrote:
How would I discard that massage? I don't see any way to discardAs FURRYe38 said "disregard" the message. As in, ignore it.
Óscar wrote:
Please fix this problem.Please read the previous conversations.
The only problem is in the inability of some people to ignore a meaningless message.
Netgear knows about this bug in its app it and has said it will mend the thing.
That message has no effect on how a modem/router works, so don't expect immediate action. There are more important bugs to fix that really do break things.
Experienced users go nowhere near a mobile app in the first place.
- JoeM11Jul 29, 2021StarDo you work for Netgear? You sound just like them. We all should be able to us the App…period…hard stop
