JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
Jul 28, 2021Guru - Experienced User
You'll need to disregard the FW update message in the app.
Óscar
Jul 28, 2021Tutor
How would I discard that massage? I don't see any way to discard
- michaelkenwardJul 29, 2021Guru - Experienced User
Óscar wrote:
How would I discard that massage? I don't see any way to discardAs FURRYe38 said "disregard" the message. As in, ignore it.
