JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
Jul 29, 2021Guru - Experienced User
For users having problems with the NH app and your product model, you'll need to keep in contact with NG support as they need to review this. Nothing else we can do here in the forums.
Thank you.
