Mandy21185
Dec 21, 2022Aspirant
NightHawk app saying MR60 not supported
I just hooked up my new mesh MR60 router with one satellite. When i go to my nighthawk app it shows a pic of the router and says connecting, then goes to a screen that says MR60 The app does not sup...
Dec 21, 2022Guru - Experienced User
There a screen capture of this?
NH app is supporting of the MK system.
What mobile platform are you using? Apple or Android?
- Mandy21185Dec 21, 2022AspirantAndroid. And I'll attach pic, please note they show the wrong router in the pic. I have the mesh system with the square boxes... but it's says MR60
- plemansDec 22, 2022Guru - Experienced User
Have you tried simply installing it manually through the browser? Thats my preferred method of install
- FURRYe38Dec 22, 2022Guru - Experienced User
Please give the PC and web page installation a try. Once you get it installed, the NH app should work. I mine does.
