Mandy21185
Dec 21, 2022Aspirant
NightHawk app saying MR60 not supported
I just hooked up my new mesh MR60 router with one satellite. When i go to my nighthawk app it shows a pic of the router and says connecting, then goes to a screen that says MR60 The app does not sup...
Dec 21, 2022Guru - Experienced User
There a screen capture of this?
NH app is supporting of the MK system.
What mobile platform are you using? Apple or Android?
Mandy21185
Android. And I'll attach pic, please note they show the wrong router in the pic. I have the mesh system with the square boxes... but it's says MR60
- plemansDec 22, 2022Guru - Experienced User
Have you tried simply installing it manually through the browser? Thats my preferred method of install
- FURRYe38Dec 22, 2022Guru - Experienced User
Please give the PC and web page installation a try. Once you get it installed, the NH app should work. I mine does.
