stevengates45
Mar 02, 2021Tutor
Nighthawk App Speed Difference
I have AT&T gigabit internet and I measure speed with 2 different Speedtest Powered Apps: Nighthawk & AT&T Smart Home Manager. Both tests measure speed from the Router/Gateway. However the Nighthawk A...
Mar 02, 2021Guru - Experienced User
the difference is the nighthawk app rarely chooses the most appropriate server to test off. I don't recommend using it for speeds >500mbps. I usually recommend people test off a pc/laptop hardwired into the router.
- stevengates45Mar 02, 2021TutorI would imagine there’s a pre-built library that Speedtest is providing for the Nighthawk app and for AT&T’s app. I’m wondering how the algorithms differ.
