NeedSupport_2
Oct 11, 2018Tutor
Nighthawk App Speed test is not working properly
The NIGHTHAWK APP Speedtest is not working properly on my iPhone 8 Plus. The download speeds are 0.00 upload speeds are ok. When I take a speedtest using Ookl a, etc my internet speed is fin...
NeedSupport_2
Oct 12, 2018Tutor
AC1600 Smart Wifi Router Product R6260...this is removed from the choices above so I had to manually input this...maybe many people are having issues with this model????
NIGHTHAWK ROUTER INFO...
schumaku
Oct 27, 2018Guru - Experienced User
...or simply not added (yet) to the product lists. There was just an update of the product lists going on these days as we have seen some test formatted lists temporarily - ChristineT can you please ensure that all newer routers are added here (and not only Nighthawk routers, as also non-Nighthawk-routers can be used with the Nighthawk App. Confusion by marketing complete.
