NeedSupport_2
Oct 11, 2018Tutor
Nighthawk App Speed test is not working properly
The NIGHTHAWK APP Speedtest is not working properly on my iPhone 8 Plus. The download speeds are 0.00 upload speeds are ok. When I take a speedtest using Ookl a, etc my internet speed is fin...
michaelkenward
Nov 27, 2018Guru - Experienced User
AC2400 is a wifi speed indicator, not a Netgear model number.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
schumaku
You can be wrong my friend ... look here -> Nighthawk AC2400 Smart WiFi Router
- michaelkenwardNov 27, 2018Guru - Experienced User
Uh, oh. They have done it again.
There was a spate of ACXXXX devices a few years ago. AC1450 for example, in 2013. Then Netgear stopped using that label.
That AC2400 was too new to waft across my horizon. (I checked.) It doesn't even appear in Netgear's list of forthcoming models.
There is also an AC2400 wifi standard that Netgear uses. Such as the XR450.
They do it to confiuse people.
