PinkerPayNikon
Apr 07, 2019Aspirant
Nighthawk app Speedtest Connection Error
My Nighthawk app on iphone was fine until I did a factory reset (with the lastest firmware) but when I try the Speedtest option, it cuts off before it tests my upload speed with "Connection Error/Reb...
schumaku
Apr 11, 2019Guru - Experienced User
Run the Speedtest from the router Web UI again instead "remote" from the App. Same problem?
PinkerPayNikon
Apr 11, 2019Aspirant
Yes it works fine on my Macs UI, I guess it's just an app bug?
| 41.59Mbps | 3.39Mbps |
- schumakuApr 12, 2019Guru - Experienced User
One more for the almost open end list ... probably more one more API inconsitency (works OK e.g. with the R9000 here) BretD Christian_R please.
