Crimson_Knight
Jun 03, 2023Tutor
Nighthawk App stuck on login screen
For some time I haven’t been able to access the Nighthawk app because it is stuck on the login page. I uninstalled and reinstalled the app, rebooted the router I even went as far as performing a full ...
Larry22222
Jun 04, 2023Aspirant
Had very similar problem this morning. Turned off WiFi and connected with Anywhere Access.
Turned on WiFi and app worked fine.
Crimson_Knight
Jun 04, 2023Tutor
Thank you for the suggestion, it was something I hadn’t tried yet. Unfortunately, it was to no avail. I also tried sending a screenshot video to show the process I was doing but this website doesn’t support the file type.
- FURRYe38Jun 05, 2023Guru - Experienced User
Try this?
What model NG product do you have?
- Crimson_KnightJun 05, 2023TutorIt’s the R7000 AC1900 smart Wi-Fi router.
I purat chased it at a second-hand store, so there were bound to be a few issues that could have been wrong with it already, but so far it’s worked for what I needed to do. The app, however, has been giving me trouble for months now. I’ll look through the steps you provided in the link and try to figure it out, I’m not the most tech-savvy guy so I’m a little hesitant about trying this myself because it’s my first attempt to do this and I don’t want to get it wrong. Software isn’t my forte, my skills are much better suited for hardware.- FURRYe38Jun 05, 2023Guru - Experienced User
Ya my R7000 was second hand as well. I haven't tried lately. Just when I saw this issue, that's the post I made when I found the way to get the app working with it. NG seems to change the app every so often and seems to break things rather than fixing sometimes. 🙄
