sdlewis2's avatar
Jan 03, 2022
Nighthawk app times out before I can login to admin. I have Nighthawk R6700.
Until yesterday, January 1st, my Nighthawk R6700 and the app worked great. Then last night and today, the router will go offline and the app will not recognize my password for admin. I have gone through password recovery and reset it. I can login on my computer just fine, but I can't use my tablet or phone. I am using an iOS system if that helps. I'm not super tech savvy, but I get around okay. I reset the router and it is on and working because we can watch tv and we stream everything.
  • plemans's avatar
    If you're able to log in through the browser fine, I wouldn't worry to much. it could be just an app issue.
    Have you tried going into your app and clearing cache/data?
    • sdlewis2's avatar
      sdlewis2
      Tutor
      I tried to clear the cache data, but it didn't seem to help. You're right, I can always log into my computer, I just don't get on here a lot because the tablet or phone is just way easier to access when the internet is running slow. I just need to learn to be patient and not go to the fastest thing around. Thank you for your help and suggestion.
      • michaelkenward's avatar
        michaelkenward
        Is this "local" (wifi) access or Anywhere Access (cloud)?
