nmara
Mar 28, 2021Tutor
Nighthawk App timing out after a firmware update to R7900P
I have a Nighthawk R7900P and yesterday I updated the firmware, based on an email from Netgear. Now when I try to access the Nighthawk APP, it tries to login and then I get "Logon timed out, please ...
- Mar 29, 2021
A factory reset of the router and then reinstalling the router. Sometimes firmware changes enough that old settings need to be cleared out.
Mar 28, 2021Guru - Experienced User
If there's issues after a firmware update, a reasonable first step is a factory reset and clean install. By clean, I mean don't install from a backup configuration.
- nmaraMar 28, 2021Tutor
Thanks for the suggestion. Are you suggesting a reinstall of the router or just reinstalling the nighthawk mobile app? I tried reinstalling the nighthawk app and it was more of the same
