MGogulapati
Feb 15, 2025Tutor
Nighthawk app: Unable to access "Account Management'" page - Shows white screen with blue title bar
Nighthawk app Version: V 2.43.0.4421 I was trying to reinstall the Nighthawk app on "Samsung Galaxy S21" and was unable to login into the app. It shows a white screen or page, as soon as it comes...
MGogulapati
Feb 16, 2025Tutor
I believe Netgear is forcing users to buy one of the Netgear Armor Security or Netgear Armor Plus products before login into the nighthawk app. There is NO option to bypass or skip the step for login, when you reinstall the app on a different phone for the existing router device.
Feb 18, 2025Guru - Experienced User
There should be a (x) on this screen or swipe down, up or right to continue past. Don't have to buy anything.
- MGogulapatiFeb 18, 2025Tutor
Not true. NO X is found on the screen or anywhere.
- FURRYe38Feb 19, 2025Guru - Experienced User
Have a screen capture of this?
