ButchJ
Apr 08, 2019Follower
Nighthawk app versions?
I stumbled across the fact that a Nighthawk app for my android phone exists to control my router so I downloaded and installed it.
Then I went to YouTube and found a demo of CES2019, but that demo...
DexterJB
Apr 08, 2019NETGEAR Moderator
Hi ButchJ,
Welcome to the community!
As it stands, the R8500 is not among the models that support the Circle Parental Controls feature. We will keep this link updated as more models are added. As for Armor, only the R7000P, R6900P, and several Orbi routers are currently supported. As for the Network Map, it should be among the available features for the R8500.
Dexter
- schumakuApr 08, 2019Guru - Experienced User
My complaint above ref. Nighthawk App does relate to the lack of controls Live Parental Control ... that wasn't the OP.
Yes, the Network Map is a feature on the local Web based Genie, is available on the Genie App - but not on the Nighthawk App, except in that Netgear CES2019 marketing video.
So still no real answer to ButchJ' question.
