frasic
Nov 11, 2020Aspirant
Nighthawk App without link internet port
hi,in my area i haven't fast internet (FTTH and more)for this reason I have internet by antenna and I connect without the internet port of the router. Nighthawk App can't connect (can't ignore that s...
Nov 11, 2020Guru - Experienced User
so you have internet through an antenna connection.
It must have its own routing capabilities if you're hookingg the router through the lan port?
sorry, the description leaves out a lot of details.
Have you tried the RAX in ap mode? (access point)
That disables its routing capabilities and leaves whatever is controlling your antenna setup running the routing capabilities.
- frasicNov 12, 2020Aspirant
I have the antenna and its cable rj-45 through lan port (not WAN) and i have an another upstream router of my internet operator that it is not under my control. I'm limited but the internet works quite well; for example, for port forwarding I have to hit the phone (sorry, I don't know if I answered the question).
I try to set the ap mode and I'll let you know if I've solved the fact
Francesco
