frasic
Nov 11, 2020Aspirant
Nighthawk App without link internet port
hi,in my area i haven't fast internet (FTTH and more)for this reason I have internet by antenna and I connect without the internet port of the router. Nighthawk App can't connect (can't ignore that s...
frasic
Nov 12, 2020Aspirant
I have the antenna and its cable rj-45 through lan port (not WAN) and i have an another upstream router of my internet operator that it is not under my control. I'm limited but the internet works quite well; for example, for port forwarding I have to hit the phone (sorry, I don't know if I answered the question).
I try to set the ap mode and I'll let you know if I've solved the fact
Francesco
frasic
Nov 14, 2020Aspirant
nothing, fails to detect the router during setup in the app Nighthawk
- plemansNov 14, 2020Guru - Experienced User
Try setup using a hardwired device (laptop/pc).
try access point with the antenna incoming connection in the wan port.
- frasicNov 14, 2020Aspirant
I started over again with the configuration of router and set AP wireless mode: for a second, the router is connected with the nighthawk app, but i don't like that mode and i disabled. thank you very much
plemans wrote:Try setup using a hardwired device (laptop/pc).
i'll tryFrancesco
