CorpDavid
Sep 02, 2020Follower
Nighthawk app won’t connect after setup is complete
I used the nighthawk app to setup the ex6100v2 WiFi extender. It completed successfully and did the firmware update.
However now the nighthawk app cant find the ex6100v2. Says it’s not setup and it looks like it is trying connect to it using the default name NetGear.ext and can’t find it.
But I can connect to the Home WiFi on my iPhone thru the neat gear extender. I can tell because when I remove the iPhone from the area the device led turnd off and goes back on when I bring the iPhone back.
I am wanting to use the nighthawk app to monitor devices connected to WiFi.
1 Reply
Sort By
CorpDavid wrote:
I am wanting to use the nighthawk app to monitor devices connected to WiFi.That's usually a router level thing.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
