mikeanello
Jun 07, 2020Aspirant
Nighthawk App won't connect to router
All of a sudden starting yesterday my nighthawk app stopped working and I can no longer access my router. If I connect with 192.168.1.1 from a web browser I can log in as admin and everything works. ...
Christian_R
Jun 10, 2020NETGEAR Employee Retired
Hello Mike,
May you try reinstalling the Nighthawk app and provide us with the current firmware version your router is on.
Thanks,
Christian
mikeanello
Jun 11, 2020Aspirant
I already uninstalled the app on my android phone and re-installed it. I also loaded the app on my ipad and have the same result. Web URL access works from Chrome, the APP does not. It worked fine for the first 2 months or so. The router is up to date. The version is: V1.4.1.50_1.3.10
- Christian_RJun 12, 2020NETGEAR Employee Retired
Hi Mike,
Thanks for confirming. I would recommend performing a factory reset and running through the setup assistant again. Use the Nighthawk app to run through the setup assistant.
Christian
