Jeanh1969
Sep 25, 2020Aspirant
Nighthawk App won't save my wifi name change
Just set up my router and wanted to change my wifi network names. For each band it takes the information, says it's updating the router, then gives me a "failed to save" message. What is the proble...
michaelkenward
Sep 27, 2020Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- Jeanh1969Sep 27, 2020Aspirant
Thanks for the reply. I have only this device, no router behind it. As to the firmware, I don't know, but it is now not terribly important. I deleted the app from my phone, and reinstalled it. The only thing I did differently from my first try was on my second installation I did not enable the fingerprint ID option. This time around, no problem. Change network names, passwords, etc., without a glitch.
I appreciate you following up.
