Sledghammer
Jan 06, 2019Initiate
Nighthawk App
I just converted to a Nighthawk R8000 wirelss router and have access to it with the Netgear Genie app on my laptop and my Samsung Galaxy phone app. I downloaded the Nighthawk app and cannot access t...
Sledghammer
Based on some reading, it looks like the Nighthawk app is not needed. I will just uninstall it and use the Genie app.
michaelkenward
Jan 06, 2019Guru - Experienced User
Both apps should work.
The Android genie, unlike the Nighthawk app, does not insist that you have to be connected to a Nighthawk router. It will happily do its stuff if you approach it through an Orbi router or access point.
The Nighthawk app forces you to use remote access to get in. Remember, login details for that are not the same as for local login.
- schumakuJan 06, 2019Guru - Experienced User
Genie support for Orbi will be revoked soon. Nightawks might follow.
Don't agree, the Nighthawk App can login locally if connected to that very router (W)LAN. It might require the configuration of a myNetgrar account however.
- michaelkenwardJan 07, 2019Guru - Experienced User
I thought it was clear from the context, but let's remove any confusion. Actually, the "if connected to that very router" bit gets us part of the way there.
The Nighthawk app forces you to use remote access to get in if you are connecting via an Orbi.
This is not true for Netgear's Android genie.
In my case, I have an R7800 as a router and a set or Orbi kit running through an Orbi base station.
