lm31243
Sep 07, 2019Follower
Nighthawk app
Cannot find the app at the app at the app store. Keeps coming back "no resluts found"
michaelkenward
Sep 08, 2019Guru - Experienced User
Android? iThings?
What search?
- schumakuSep 19, 2019Guru - Experienced User
On https://www.netgear.com/home/discover/apps/genie.aspx there is a pop-up with links to the Nighthawk and Orbi App on the App Store and Google Play.
- michaelkenwardSep 19, 2019Guru - Experienced User
Along with the usual "X" to dismiss that pop up.
