Trndkil3
Oct 20, 2019Aspirant
Nighthawk App
When using the android Nighthawk app remotely or locally the device manager does not show a pause/unpause toggle for any device on my network. What is the problem? I have reinstalled and restarted eve...
Trndkil3
Oct 22, 2019Aspirant
My firmware version for my router is v1.0 1.50 and I'm on Android 9,One UI 1.5
All forms of logged into router have no option for toggle pause/unpause either from a browser, my phone, or the windows netgear app on my laptop. There simply is nothing to toggle.
schumaku
Oct 22, 2019Guru - Experienced User
Just in case: The router isn't possibly operating in pure wireless access point mode?
You might want to try the unbiquitous Netger problem reoslution approach and do a factory reset of the router, and reconfigure from scratch and re-test. If this does not resolve the issue(s) - clearly a router firmware issue. Why oh why I'm not wondering anymore about this mess ChristineT ?
- Trndkil3Oct 22, 2019AspirantI'll try a factory reset and see what happens. I did notice that when trying to troubleshoot on the Netgear site they don't even show my router any longer so possibly they dropped support of it and in turn disabled that feature to get me to buy a new one?
Feels like when the new model of your current phone comes out.....you have problems with your old phone....the battery stops charging, drop calls, or you have to constantly reinstall or restart it to get working again. Seems like that kind of vibe.- schumakuOct 22, 2019Guru - Experienced User
Trndkil3 wrote:
I'll try a factory reset and see what happens. I did notice that when trying to troubleshoot on the Netgear site they don't even show my router any longer so possibly they dropped support of it and in turn disabled that feature to get me to buy a new one?.Not sure what you have noticed ... https://www.netgear.com/support/product/R6400.aspx
