Jo85
May 07, 2020Aspirant
Nighthawk app
So I just got a new Netgear cm1000 modem and I can not get the app to connect to router for remote access. I have reset both modem and router still can’t get the app to connect.
michaelkenward
May 09, 2020Guru - Experienced User
Does the Nighthawk app support the CM1000?
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
The manual is also silent on this.
