Jo85
May 07, 2020Aspirant
Nighthawk app
So I just got a new Netgear cm1000 modem and I can not get the app to connect to router for remote access. I have reset both modem and router still can’t get the app to connect.
Jo85
May 09, 2020Aspirant
I can’t get the Night hawk app I used to setup the router to connect to the router. I only started having this issue when I got my new modem the CM1000
michaelkenward
May 10, 2020Guru - Experienced User
And that router is?
Setting it up and using the app should not need the CM1000 to cooperate.
