erink883
Aug 16, 2020Aspirant
nighthawk app
So after a lot of frustration with the app and trying to trouble shoot myself i decided to delete the app but now it shows up as a blank white app with some lines and i can't get rid of it even if i ...
michaelkenward
Aug 17, 2020Guru - Experienced User
erink883 wrote:
So after a lot of frustration with the app and trying to trouble shoot myself i decided to delete the app but now it shows up as a blank white app with some lines and i can't get rid of it even if i restart my iphone. Anyone else have this same issue? if you have please help. Thanks so much.
Which app? Android or iOS? (I'm guessing the latter, for various reasons, but it helps to know.)
- erink883Aug 17, 2020Aspirant
Oops. It's an iPhone.
- michaelkenwardAug 17, 2020Guru - Experienced User
I am too mean/informed to buy anything from Apple, so I don't know how the apps process works on iOS.
In Android, I simply tell the phone to remove the app, or, if I just want it off the screen, I remove the icon.
Thanks for your input
