britman98
Oct 13, 2020Guide
Nighthawk App
The Nighthawk app keeps telling me that my wifi router is not supported.
britman98
Oct 13, 2020Guide
Yes router is R6900P and connected to the internet, tells me there is no internet connection and then Nighthawk app does not support this router!
Oct 13, 2020Guru - Experienced User
Modem using?
Firmware on router?
Everything else works other than the app?
- britman98Oct 13, 2020GuideModem is a spectrum modem, no manufacturer name on it just property of Charter communications! Firmware is: V1.3.1.64_10.1.36. Yes everything else seems to be ok!
- plemansOct 13, 2020Guru - Experienced User
Sometimes spectrum installs modem/router combo devices.
There should be some model number on the label for it.
Also, you can use the browser to access/modify the router.
