Cooleytn's avatar
Cooleytn
Nighthawk app
Are people have Trouble Connecting to the router with the nighthawk app. I have downloaded the new firmware on my router. Thing was working good used the app on my phone then jan 1 the app would not connect the router. It ask me to reset the router with modem. I did all that it work for a min turn my cell off and now the app is not connecting to my router. Need some
  • What router do you have?
    What firmware are you on?
    What modem do you have?
    did the issue start after you updated the firmware?
    • Cooleytn's avatar
      Cooleytn
      What router do you have? Nighthawk x6s model R7900P
      V2.7.2.1373
      Motorola docsis 3.1 cable model mb8600
      did the issue start after you updated the firmware? Yes i install it from the app and now I cannot log in through the app it keep asking me to reboot router and model R7900P.
      • plemans's avatar
        Guru
        V2.7.2.1373----that's probably your app version. Log in to the router through the browser and check which version of firmware you're on.
        The firmware version you put is for the app I believe. The R7000P's latest version is 1.4.1.66. I've seen a few people on here with app issues on that version. they actually downgraded back to 1.4.1.64 and the app worked again. If you use this method, do it over a hardwired connection for best results.
