Lcadet
Feb 09, 2021Aspirant
Nighthawk app
I have the XR500 and EX7700 the app on IOS has never worked properly. Here are the issues I found an hope you can help me. XR500- cannot see devices connected. This device is on the latest firmware ...
Lcadet
On the dumaos web interface everything is ok. I can see all devices and can stop, delete etc. as needed. Other than change the Wi-Fi passwords, enable guess wi-if and test the internet speed there is 0 functionality on the app.
Feb 09, 2021Guru - Experienced User
you could try uninstalling/reinstalling the app. But I wouldn't worry about it to much if the browser is working fine
- LcadetFeb 10, 2021AspirantRe-installing does nothing to add the functionality required. Are you really saying that Netgear made a useless app but we should be thankful that the browser works?
Does your app work? Using the browser for these basic functions is not practical. Further than this the Dumaos has its own problems but I will save this for another tread.
Any real answers for the issue at hand??- plemansFeb 10, 2021Guru - Experienced User
Did I say you should be thankful? No. It sucks the app isn't working properly.
But an app not working is a different issue than a router not working.
So if I had to choose? It'd be an easy choice.
Maybe something was corrupt in the app. Maybe the app had a bad update. Maybe the phone did an update that caused issues with the app. But I'd rather my app not function properly and still be able to login to the gui to make changes versus the router being the issue.
