Copejack
Sep 21, 2021Guide
Nighthawk App
Can anyone tell me if there is any part of the Nighthawk app that works without issues? It seems like anytime I switch between various features within the app is very unstable. Just get the app to con...
Sep 22, 2021Guru - Experienced User
I'm not a fan of the nighthawk or the orbi app. Seems like half the time it works, then it gets updated and breaks.
I prefer to just log in through the browser to manage the router/devices.
Copejack
Sep 22, 2021Guide
Yes, I use a bowser as well and perform some tasks that way as well.
However, from a end user perspective, I expect the Nighthawk app to function properly with minimal issues. Any feature you use inside app works, at best, 50% of the time. It struggles with page switching when using the app.
