Copejack
Sep 21, 2021Guide
Nighthawk App
Can anyone tell me if there is any part of the Nighthawk app that works without issues? It seems like anytime I switch between various features within the app is very unstable. Just get the app to con...
Homeuser66
Sep 28, 2021Guide
You're not alone! I have also had these same issues from day 1. When I talked to Netgear, they admitted they have issues with the app. They wanted to upload a firmware for my router that might fix the issues. I declined as it was brand new and I just finished hours or adding all my wifi devices and naming them on my network. Didn't want to start all over again. They told me I could do it later (in the future) but they declined to tell me it was only in the next 20 days! As far as loging in on the web, that also works once in a while for me. Website keeps telling me I need the Nighthawk app installed (yes, even in a Windows Environment) If I knew there was so many KNOWN issues with this app, I would never have bought it! Otherwise, this modem (CAX80) is great!
