TristenB34
Jul 28, 2022Follower
Nighthawk app
My app doesn’t let me connect with the QR code it says it’s connecting then doesn’t let me continue
If you're on ios make sure that icloud relay and private mac/ip address is disabled.
Hi TristenB34 ,
It is a known issue and NTGR had fixed it, will release the new version app after 8/3...
For now you can use either ways below to work around it.
- Fresh install APP --> Sign in SSO --> Don’t kill the app and re-launch it --> QR code scan --> tap Continue button --> Can finished the install setup then go to the dashboard
- Fresh install APP --> Sign in SSO --> Don’t kill the app and re-launch it --> Set up NH manually --> Can finished the install setup then go to the dashboard
