Retired_Member's avatar
Retired_Member
Mar 19, 2023
Nighthawk App
I can’t sign into the nighthawk app under my admin sign on. I am able to sign onto the router login.com with my admin sign on. When I try on the app nothing happens it just stays on the sign in page. Yes, I’m using the correct password.
    Sign in where?
    Which Netgear device are you using?
    First you have to sign into the local WiFi. Done that?
    Then you can get into the router itself.
    • Retired_Member's avatar
      Retired_Member
      Nighthawk CAX80
      I can’t sign into the Nighthawk APP. I am on the wifi, I can sign in online just not on the App.
      • michaelkenward's avatar
        michaelkenward
        Guru
        Nighthawk CAX80
        Android? iOS?
        Any useful messages when you try?
        Tried removing and reinstalling the app?
        The CAX80 should be app friendly out of the box. But you might want to check that it has the latest firmware.
        What firmware version do you have on the router bit of this modem/router?
        A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
        While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
        You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
        Cable Modems & Routers
        You might like to search there for messages related to your problem.
        I will ask the Netgear moderator to move your message.
        In the meantime you could visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
        Check for various troubleshooting tips.
        You may have done this already. I can't tell from your message.
        I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
